skyrush2
i'm starting on my rear suspension radius rods is it best to weld bungs to the frame to connect them or just run a bolt through the frame?
pics would be cool.. just tryin to get an idea
If you are still interested?Bung or something of the sort!
I machined out some of my own bung/spacers from solid shaft and put a 7deg. taper in them for the tie rod end to fit into.Looks like the tie rod is just bolted to the frame but on the inside of the frame it is resessed so that the nut and cotter pin is hidden. I can take some pics if you want.
