Had to put a small bend in drag link to clear left tire when in full left turn. Drag link is heavy wall 1" ID. I think its good but wouldn't mind some thoughts. Thanks.
It's best if you don't bend them because it does take some strength away and makes it more prone to folding at that spot. That being said, even some stock draglinks on cross steer applications have a bend in them for engine clearance, so who knows.
I would keep an eye on it to make sure the bend doesn't also want to loosen up the rod ends, from twisting action. But you should be ok, especially with that OD of tubing.
