EZ Wire Kit Question.
sgo70
May 25, 2008
220
Calgary, AB
I'm trying to get my wiring done and I ran into a problem. I have an aftermarket Spal fan that comes with it's own wiring kit. It has:
1. wire to battery
2. wire to fan
3. wire to sender
4. wire to ignition
All these wires come together in a relay.
No problem pretty straight forward. The problem is the EZ wire kit, it has:
1. one wire to the engine labelled "fan"
2. two wires under the dash "fan power" and "fan fan"
I think the #4 ignition wire goes to the "fan power" wire and the other two can be cut but I'm not sure. Anyone ever had this problem??
Thanks,
Sean
Sean,I would just do it this way considering that it has its own stand alone relay and you will be fine.I did it the same way.
1. wire to battery
2. wire to fan
3. wire to sender
4. wire to ignition
