gas tank outlet too small? what size pump
frankr
Oct 16, 2009
47
Cumberland Ontario Canada
The original gas tank on my 34 Dodge has a 5/16" outlet.
Will the 5/16" outlet be enough to feed the twin Edelbrock 600 cfm carbs on my 392 Hemi?
I will use an electric gas pump; what gpm do I need?
Will 7 lbs at the pressure regulator be OK?:confused:
RRR, Thanks for your help so far.
FrankR
1934 Dodge 392 Hemi
My opinion:
I'd much rather see a larger diameter tank outlet. If it were my car, I would change it with a new bung to at least 3/8" or -6AN. I have a 392 hemi, it's pretty thirsty. Seven pounds at the regulator outlet might be a tad high for those Edelbrock carbs but would work. I would try 6 or 6.5. Ony 90 GPH or above fuel pump should suffice. Below is a link to an article that you may find helpful.
http://www.centuryperformance.com/f...tanding-fuel-pressure-and-volume-spg-140.html
