Sid
- Joined
- Apr 19, 2009
- Messages
- 114
I just picked up my 8BA flathead block from a local flathead builder and long time drag racer Earl Floyed. It's been acid dipped, magnafluxed, and releaved. I'm going to do some cleanup work on the intake and exhaust ports then take it in to be line bored, and decked.
This will be my very first engine rebuild and I will be assited by Earl as I'm sure there are many little tricks to building them that I would otherwise be unaware of.
I'll be installing a Merc Crank, stock rods that have been shot peened, stock valves, and Egg forged pistons. I did pick up pick up a Aluminum T7071 heavy a** duty main cap that Earl has made that he runs in his dragsters that should toughen up the bottom end.
I decided to go with a 2x2 carb setup so I can run the generator in it's stock location.
Sid
Sid
