kelseydum
Pressure seems okay when warming up but drops when it is fully warmed up. I can't hear any knocking, no metal in the oil, and the oil pressure gauge is good. My problem is when I bought the motor the guy said it was a 350 with maybe 9k miles (said it was a crate motor, but I'm not so sure now). I finally looked up the numbers on the block and it turns out to be a 305. I really don't care about that part but I put a beefier cam in it (thinking it was a 350) and am wondering if I have too much lift for stock 305 valves, rocker arms, push rods etc. Any ideas? I'm going to cut open the oil filter tomorrow and see what's inside.
I put a Mellings cam with the following specs:
Cam Lift
INT. .298
EXH. .298
Valve lift
INT.447
EXH. .447
Lobe CTR
INT. 110
EXH. 118
Lash Hot
INT. HYD
EXH. HYD
SAE Duration
291 INT.
291 EXH.
.50 Duration
223 INT.
223 EXH.
SAE Timing
BTC 30
Cam Lift
INT. .298
EXH. .298
Valve lift
INT.447
EXH. .447
Lobe CTR
INT. 110
EXH. 118
Lash Hot
INT. HYD
EXH. HYD
SAE Duration
291 INT.
291 EXH.
.50 Duration
223 INT.
223 EXH.
SAE Timing
BTC 30
