Hi I just found a deal on a dual carb intake and for 200cad I'm just curious about the Downfalls of a dual carb setup, like will it cut fuel economy in half or do they just not have to work so hard?
Some of it depends on how you drive and how heavy your right foot is. You can run progressive linkage and have single carb economy under normal driving conditions and have the second carb come in under moderate to heavy acceleration depending on the manifold design. 200 Cadillac?
If you want some show... go with multiple carbs.... I have two 600 edelbrocks on the 421.... progressive linkage...runs off back carb till I jump on it.... probably too much carb...... seems to handles it ok... but sucks the fuel when you are into it too much..... just looks really cool...
The performance will be less than the single 4 barrel due to uneven fuel distribution, however, that didn't stop me from using it on a bbc. The problem is more pronounced on the bbc than a sbc. The Offenhauser is a better design than the Edelbrock I used (lowriser).
