Which straight 8. I am building a straight 6, Pontiac. Stock it had 85 hp, we, my engine builder and I, think we can get around 200 hp.
Changes include, 3/4 ground cam, bored .060 over, milled head .183, larger valves, move spark plug location, relieve combustion chamber, Edmunds intake, custom exhaust, magneto, hardened valve seats.
Stock compression ratio was 6:1, new comp ratio will be around 8:1. Also adding a remote oil filter, stock did not have a filter, not a horsepower boost but will allow the engine to have less wear.
One of the most important things are the pistons. Originals were cast, we are using aluminum. You have to search around a bit and find out what pistons will work.
In the end I really don't care too much about the HP, more important is having an engine that you don't see everyday. With the proper trans and rear end ratio you could run that straight eight all day at freeway speeds.
