Lakota
Rides a rusted horse
So far I've changed the gasket on my TH350 trans three times and they all leaked. The last time I changed the pan and the gasket. Normally I use a cork gasket with the red goop sealant. What do you guys use?
Those pans warp easy if you use a screwdriver to pry them off. I use a putty knife or something thin.
i weld a drain plug into my pans i can drain the oil out easyer before i undo the pan and make less of a mess using the tilted pan method
