Warm toes in minnesota...
DOUGIEB59
Aug 12, 2010
133
MID TN, NOW
Guess who's gonna have warm toes this winter...
hey! just pre plan where your lift is going. And WRITE IT DOWN! don't ask me why but radient heat doesn't work so well with a lift lag bolt in a tube. Just sayin....
Looks good![cl
That could really ruin your day......
Looks good![cl
And that is a load of pipe running around.....could get ugly....:eek:
Interesting, I had run quite a bit of that line when I was in HVAC years ago, it is really cool stuff, just make sure you have it weighed down good or screwed down to the height you want or it can float up... looks like you have the spacing pretty good, closer together out where your heat(cold) load will be at the walls, and more open in the center. Don't forget to use the antifreeze fluid rather than plain water for the boiler.
All i need now is a hammock, and a good dog... Maybe a spaniel of sorts, or an austrialan shephard...??
