Calculating displacement!
Tripper
May 10, 2007
14,174
Central Tejas
Since I bored my Nailhead .03 over... I wanted to re-figure the displacement. I found this simple formula for doing so...
Bore X bore X stroke X .7854 X # of cylinders = displacement
Also if you want to go from liters to cid or the other way the factor is 16.39
4.3L for example is 4300 divided by 16.39 = 262.35 cid. multiply to go the other way. 350cid x 16.39 =5,736 or 5.7L
cubic inches
Havent messed around with a nailhead, but a small block chevy .30 350ci would make 355, and a .60 would produce 360ci. If your under 400ci I think you add 5ci per cut and above 400ci you would make 10ci per cut assuming stock stroke, rod length and deck height.
