First time building a car completely. Custom frame, air bags, etc. Using a TH350 for transmission. This is a newly rebuilt transmission (no fluid in it). I'd read anywhere from 9-11 quarts on a completely empty trans. I'd poured a quart in the torque converter prior to stabbing it in the car. I poured two gallons in it from the dipstick tube and about 20 minutes later I started seeing a drip from the rear seal. When I pulled the driveshaft out to check the seal, about 2 quarts fell onto the floor. The car is sitting level in the garage on jack stands as I'm not quite ready to drive it yet. Did I overfill it? Is there an internal seal that failed? I didnt rebuild the trans, my dad bought it from a friend that does them. One side note question. The output shaft has a slight side to side play. Is that normal? Thanks in advance guys!
