Here is the frame I started on i got the rear mounted finished welding all the brackets today first time for me using air bags on the rear iI also turned the body upside down and cut all the floor out. Got a Speedway roadster front end for it. and I have a V 12 Jag engine and 350 turbo trans for it. I have removed all the electronic fuel injection from it used the original intakes and machined them and welded up boxes for carbs using 2 450 cfm holleys I will get some pictures fo the set up soon
