what technique do you plan to use to lower the front end that far?
I switched the axles from under to over the springs. This may be as low as I go for now. I will still need to notch the frame.
I don't see a motor. With a motor, your front axle is probably just about going to be on the frame or the pan with those worn out springs. Even with new springs. These trucks lean hard in the front in a fast corner.
It still has the 292 in it and I have 2" between axle & frame. After I notch the frame I will have 5". The oil pan is the problem right now. But the SB. 350 has the sump in the back so I believe it will be OK. I will find out when I get the eng. & trans. in.
Got a before picture?
Looks nice, I would like to see the actual difference as I have a Dodge D100 I want to lower the easiest and inexpensive way that still looks pretty low.
