smallfoot
I'm betting on lever changes to fix it. Mine will be done here shortly and I'll let you know how it works. This one had 1" dual mc to start, I have a brand new one. New 3/16" lines to replace the same size that both of my donors had. 1953 F100 brake cylinders,and drums, 1971 Jeep rear brake cylinders and drums. Now, I have the original jeep pedal but it's ratio is really bad as far as I'm concerned and will be fabbing my own pedal. The Jeep one has the pin set 3" from the axis, and the lever is only 14". That's less than 1/5. The jeep was light and I guess it might have been ok but I'm going longer for sure because I don't want a hard pedal and no brakes. I believe the system will match as close as two different ones can. And I believe if I make sure to fit things right for a long pedal I can make it brake easy enough.
