If you're tight on cash, skip the tool chest, the 301 piece set, and the air stuff. That 301 piece set has a bunch of stuff you probably don't need or want. I generally try to avoid buying from HF anything that should have a sharp edge to it. Pliers, bits, saw blades, etc. Their flapper discs are worthless too.
Get impacts for any 1/2" sockets you buy - since you'll get air eventually. But just buy a 1/2" ratchet, breaker bar, and torque wrench. Buy the 3/8" and 1/4" socket set. Some extensions and adapters too. Get a full set of wrenches. Maybe a set of gooseneck box wrenches. Set of screwdrivers or 2. Crow bar.
Get your pliers somewhere else. As for channelocks , I love my Vise-A-Grips. Nothing works as well in my opinion. Get a pair of wire strippers too - my all time favorites are
GB Tools GESP-70. You can find them cheaper I suspect.
HF's step bits are good.
I also use HF's 4-1/2" grinder and cut off wheels. get a full face shield. Their 4-1/2" grinder is about the only electric stuff I'd buy there. Definitely don't buy cordless stuff there. Corded models are dirt cheap.
Save your cash and buy a decent welder.
