Darksyde
So new builder, picked up a 1941 Ford 1 ton. This truck I found out had its running gear changed out at some point, to a 1949 engine and rearend. Truck is now in my garage. Old flathead removed. Just working on removing the cab so I can get at the Frame. Have a 1995 F150 donor with a 351w, a c4(from different truck), and a 8.8 rear.
With the 1 ton axle I'm going to build some brackets to run a elliptical front end.
