Several things you will need to think about, first is a carb. You will need to build or buy a blow through carb. Second, you will need an electric fuel pump and a boost sensing fuel pressure regulator. With those things covered, it will go something like this: you add boost , you have to add more fuel pressure . You will need a boost referenced fuel pressure regulator for this . It will raise fuel pressure 1:1 . ( 1 psi of fuel for every 1 psi boost ) example : base fuel = 7psi add 10 psi boost , and fuel pressure will rise to 17 psi . It is easy to do, you just have to make sure you DON'T use a mechanical fuel pump, it can't increase the fuel fast enough.
