Fix the A
52stude43
Jan 24, 2012
57
Cottonwood , MN.
picked up a failed project a while back , had a mini truck frame with a drop center welded in , sat low , when you had a flat the frame would sit on the ground , nice if you have air-bags , but not with suspension and no motor installed yet , so I decided to change it up a bit , the drop section of the frame was built pretty nice and square with 2x3 tube so I will be saving that and re-doing the ends , the body started out as a 2 DR sedan that an old farmer turned into a pickup way back when , didn't do to bad a job with the building tin on the back:D , a buddy needs the tops of the doors for a bad chop on his coupe so I will build a roadster PU. out of it.
here we go , cutting off the ends , and here's what we have left , up on the jig we go after we cut off the top and back
on the jig , mark the ends that need trimming and cut out tube for the kick up
built a rear box section out of 2x4 tube [;) square up and weld [;) then on to the front , 2x4 tube with a 3" front cross-member , setting up front like a T-bucket , then more welding [;)
here she is , much better , bent up the tube pieces and welded [;)have some more grinding and a few gussets to put on then have to hit the swaps for some axles and parts and build up the rear of the body ,will keep you posted
Did you leave any room to stretch the cab back? Won't that be cramped?
I can't believe you got rid of all that fine looking tin work! :rolleyes:
the back of the cab will be @ 12" so it will be @ 6" to 8" longer than the stock 28 RPU , the doors on a sedan are longer already than the roadster pickup , the frame will hang out @ 2' past the back of the cab , so @ a 3' box
I like what you've done so far, I'll be watching this build. Last month I bought a '30-'31 cowl and doors, I would like to make a pickup out of also.
up-date , picked up a swap meet front end , an old dirt tracker had this under an old sedan , says it was a 50's Ford axle narrowed @ 6" , he doesn't remember what the brake set up was from , Ford brake calipers with a homeade bracket and modified stock set-up , the calipers have a 5 on 5 pattern , and he was thinking full-size GM but might be a Full-size Merc ,he didn't recall , when I check the bearings out I will try and find a part # and cross-ref it to see , might be an easy bolt on to the ford spindle , If I find the numbers I will post them . as luck would have it I have a 5 on 5 9" ford rearend laying around so I can match up the bolt patterns front and back. also ground down the welds on the axle where he narrowed it
