Neophyte
Front suspension continued
It was time I worked on this poject again. I am now not too far from finished with all my major fabrication on the chassis.
Seeing that the rear shock mountings have been done it was time to do the front. First off was to fabricate two shock towers to place on the chassis next to the grill. Nothing too fancy was needed so I came with this fairly boxy design.
The first pic just shows the three pieces of 50mm x 5mm flat bar that make up each shock tower while the second shows where I tack welded them together.
In the third pic they are tack welded to the chassis with an old (mock-up) shock fitted. My next entry will show the shock mountings wishbones on the wishbones a bit closer up.
