K Ken47int Well-known member Joined May 19, 2016 Messages 52 Feb 13, 2017 #1 Anyone have any idea if the studs for the rockers are pressed in or are they threaded in? Thanks
Old Iron Well-known member Joined May 19, 2011 Messages 15,297 Location Willard Mo. Feb 13, 2017 #2 If they are factory then they are pressed in
K Ken47int Well-known member Joined May 19, 2016 Messages 52 Feb 13, 2017 #3 Thanks old iron, I kinda figured that from the little bit I looked at them last night
Torch Extremely dangerous with a torch!!! Joined Jul 18, 2008 Messages 1,627 Feb 15, 2017 #4 you can install screw in studs if using high spring pressure with a radical cam but a good trick was to pin the studs to the casting by drilling through the head and stud and installing roll pins.
