lowbudget50
- Joined
- Sep 23, 2012
- Messages
- 5,943
So I am in the process of rewiring the 65 Ford pickup that I have been working on. I've come to the interior where I need to wire in the steering column. The problem is all the wiring diagrams I can find and the one that came with my harness do not even come close to matching the color combinations that come out of this column. I have dug around on a couple F100 sites looking at different columns and different color combinations. I cannot find one like this. To be honest the closest one I have found is a 65 Mustang, but it is not right either. I would pull the steering wheel off of it and look at my connections on the interior of the column and the turn signal switch but someone along the way has welded a washer on to the column instead of the nut that is supposed to hold the steering wheel on. Has anyone else ran into anything random like this. I'm not wondering if the reason that the washer is welded on there and the color combinations do not coincide with each other. I'm wondering if somebody tore this column apart years ago to replace the blinker switch in it with an aftermarket one. And in the process they screwed up the steering column nut and welded a washer on there
