hillbillie hotrods
OK i need to know how far behind the axle to mount the steering box , the front end is a 4" dropped tube axle with a cross spring and cross steer with a spring perch off the front of the frame ( 3" round tube )
The drag link runs parralel to the front axle what i need to know is what angle should the steering arm should be on if any .
Should i use the cross steer or go with the suicide steer , what would you guy's do
The truck is a 41 ford with a homemade 2"x3" frame
