plug wires
49rat
Dec 16, 2010
61
Mount Orab, Ohio 45154
I was woundering if i crimped 4 plug wires into one, to go to the coil for my flame throwing header, if all 4 spark plugs would fire? I have'nt planted my plugs yet but the coil is their from my old exhaust and before i put 4 plugs in the header, I'd liked to know that they will work.
Id think the wires would work but not sure if one coil would put out enough to fire four plugs at once.
With the header tubes that close you shouldnt have to light every tube. They would light eachother. I would just light the middle two.
I was thinking the same 21willies, maybe just the middle two. Now i added some baffles to quite it down and wounder if a flame thrower would work at all??[S I made the baffles and they did quite it a bit, but now it sounds like a tractor.
I'm fairly certain only one plug will spark at any given time. But they all may spark randomly, so it might work OK. My guess is one will spark mostly with one or two others sparking rarely.
In my experience sometimes its better to have a little bit of a baffle or muffler then to have straight open pipe. If it flows to easy sometimes it will blow the flame out.
