irishmik54
Active member
My tranny has a leak where the cable for the speedo goes in any ideas of how to fix the leak?
I believe you can disconnect the speedo cable from the tranny, and remove the point it attatches to and replace a simple O-ring gasket and you should be OK.
I'm no transmission guy, so hopefully, someone else has better knowledge than I do.
