Model A Pickup just another build !
dmw56
Dec 21, 2007
6,554
Edgewood, New Mexico off Route 66
Gonna start another build. I got a cab and a frame let's get started! Well I've had both the frame and cab for about 12-13 years so I guess I started years ago.
I got the cab in Texas and the frame with some others with titles in Kansas.
    145.5 KB
    140.2 KB
    219.3 KB
I have most everything for the front end. The axle and spindles are 37-41 Ford. Split 46 wish bones with tie rod ends.The brake backing plates are Ford F2 truck with 12" Bendix brakes. The drums are 12" Buick Aluminum drums. F1 shock mounts.
    122.7 KB
    115.6 KB
    140.7 KB
    100.9 KB
I have several grilles to choose from. I'll probably use the smaller 29 Model A one. Gas tanks a bomber O² tank kinda small, but Kool and Model T tank.
    64.3 KB
    158.4 KB
    73.4 KB
I have 2 sets of headlights. I like the ones with the turn signals.
I also have a reversed Corvair steering box and a 34 Ford box and column. If I were going traditional I'd use the 34 box. We'll see. The 34 box practically bolts right in! 👍😎
    64.6 KB
    79.8 KB
    79 KB
I have the bed, tailgate, and some assorted stuff, no fenders, splash aprons or big heavy stuff we don't need!
Oh but I have a rear quarter from a 59 Catalina. Hmmmm bed maybe! 😉
    127.9 KB
    201.6 KB
    218.8 KB
10 bolt rear with brackets for hairpins, coilovers and panhard bar already welded on.
Mustang radiator. I also have a third row minivan seat.
Now I just have to put this all together.
    82.2 KB
    62.8 KB
Clean up the frame and painted it with rust converter.
I measured it for square it was right on! Really flexible with no cross members though! That will be fixed. I will go with a small kickup on the rear for a coil spring set up.
    145.5 KB
    147.7 KB
Finished one side of the brakes. 12"x2" drums. Then I couldn't find the lower spring by the adjuster. I really can't remember if I had it at all. So I look in my collection of brake springs and of course I don't I have one.
I have couple local resources I'll have to check for one.
    102.2 KB
    113.3 KB
    128.2 KB
    175 KB
As far as engines go, I have several choices.
2 AMC 360s, a 010 block SBC and a vortex SBC, and a Pontiac 389.
    116.3 KB
    133.5 KB
