Thanks ratterman. You can do anything I can do. I'm just a backyard builder.
Not much in the line of photos to show for the work this weekend or from here on out. Just a bunch of small, time consuming tasks that won't show in pictures. My brother came over and we knocked much of it out. I may be looking at attempted fire up next weekend. We'll see.
Things we got done were:
Sliced, reshaped, welded road draft tube and installed it
Finished up the fuel lines with filter and regulator which I put under the car this time.
Made and installed the vacuum line for the tranny modulator
Re-routed some of the wiring
Changed to longer studs and installed the exhaust manifolds
Put the final tightening some hardware that had been left loose until other things were done
Started on the throttle linkage. Part of the bracketry has to be fabbed.
We also made these simple wire looms to keep the plug wires where I want them. I used the threaded wire cover stands to attach them. I have the factory wire covers and will probably eventually install them because they do more than just cover the wires. Right now I like the look of the wires sprouting out of the tubes. Looks racy to me.
